Hi all. Sorry for this long post but I need to make a decision.
My current project is to lay a solid wood (maple) floor. I have the wood but am now faced with a variety of options.
This is the problem part of my floor:
http://www.flickr.com/photos/13818533@N04/?saved=1
The concrete area to the right is pretty flat and dry.
The tiles to the left- which appear to be vinyl on a bituminous adhesive, over concrete- are well stuck down and would take a lot of getting up. They do undulate slightly though near the join and would probably need some sort of levelling compound (mira x-plan?) across it. There are a lot of them and nearly all of them are straight and true.
The bodged job of joining the areas I think covers a water pipe (don't ask!). That area can however be smoothed over.
My current ultimate plan is to use Rewmar MS adhesive and glue the floor down.
Now, the concrete area is not exactly level with the tiled area and is slightly (5mm or so) higher- hence again some sort of levelling will be needed. I therefore need to consider my options:
1)I get lots of expensive levelling compound (35 sq m in all to cover) and put it over tiles and all (the Mira x plan website says it will go over almost anything) then glue down using the Rewmar adhesive. Downside=expensive and most of the tiles are level anyway.
2) I try and use levelling compound in the localised area near the join and smooth over the join to such extent that it is insignificant (thank you mattysupra for your previous response to an earlier post about this- your comment that I would have to get it very smooth makes me think it might be beyond my ability!)
3)I screw down a ply sub floor over the lot with some underlay to make it level across the join and then nail down the floor on top. Downside=it will make the floor thicker I suppose but I could live with it.
It's looking like (1) or (3), I really don't know whether (2) is feasible but it would have the advantage of not using up masses of compound.
4) I guess is to employ a flooring contractor, pay up and have done with it!
Thanks. If there are other options I've not considered feel free to comment.
