ferroli f30 timer clock
20 Sep 2005
Birmingham
I went to put on my heating for the first time since the spring and it doesn't seem to want to start, but i did notice the timer clock has stopped working (no display), i realise i need a new clock, but is this the reason the heating wont kick in. The domestic hot water is fine and has continued to work no problem. I turned the boiler off and then the power and had a look at the wires that go to the clock and followed them the other way, all the wires seem to be connected OK. I also changed the fuse on the power supply for a new one (3 amp) Any help would be welcomed, as the winter is looming. Cheers
In a standard system, not surprisingly the timeclock has to be working and "on" to power the system for heating.
Tony
OK Well me being the inquisitive sort, i took the timer out and then took it apart and to my joy spotted a watch type battery inside, i went and bought another one, changed it and the timer now works again and so does the heating Joy oh joy
Thanks anyway :D :D :D
I've had recent trouble with my Ferroli f30 boiler. There was a clicking noise coming from the timer control. I tapped the housing, the noise stopped and after sliding the on/off switch it resumed normal operation - but only for a while. The problem reoccurred with increasing frequency. I was expecting the mechanism of the clock to have broken and a replacement of the timer control to be the next job. However the comment above, about the internal battery led me to buy a replacement CR2032 3v Lithium Battery. (prices ranged from £3 to £9!) So, the outcome is now a heating system working perfectly again. You will need a fine posi-drive to remove the retaining screws of the timer and a fine pliers to detach the electrical contacts. Thanks 'DIYnot' for your web site and the helpful comments from your contributors. Happy Christmas.
