Joined: 29 Sep 2007 Posts: 6 Location: Tyne and Wear, United Kingdom Thanked: 0 times
Posted: Sat Sep 29, 2007 10:16 am Post Subject:
HOW TO REWIRE A TWO GANG LIGHT SWITCH
Hello need urgent help. Whilst preparing walls for replastering came across jumble of cables linked into connectors. Anyway need to rewire new 2 gang light switch but not sure what goes where. There are 3 cables with Red, Black, Earthing on each (total of 6 wires!!!!) the light switch is 2 gang type with Com,L1,L2 on each gang. Can you please advice. I know which is the live feed cable and i have checked the pendent fittings which all have one cable coming from it presumably running back to switch.PLEASE HELP PLASTERER DUE ON MONDAY.Many Thanks
Joined: 01 Dec 2006 Posts: 1794 Location: Cumbria, United Kingdom Thanked: 8 times
Posted: Sat Sep 29, 2007 10:33 am Post Subject:
See the Wikki for 2-way lighting circuit, but what do you mean by" came across jumble of cables", were they plastered into the wall? in a junction box?in a switch box? You need to establish which cable goes where & for a 2-way lighting circuit you would normally need a 3-core & earth between the 2 switches
Posted: Sat Sep 29, 2007 10:41 am Post Subject:
Hi thanks for quick response. Original cables where plastered into wallin connectors with tape around. There are two lights in the kitchen working of a 2 gang switch ( 1 switch operates 1 light) with 3 cables running to it, one of these cables is live i have tested with a mains tester screwdriver
Posted: Sat Sep 29, 2007 10:43 am Post Subject:
H thanks for quick response i have tested wires with oneof those screwdrivers that light up!! there are two lights in the kitchen and they operate of a two gang light switch there is no other light switch
Joined: 15 Apr 2005 Posts: 12845 Location: Yorkshire, United Kingdom Thanked: 21 times
Posted: Sat Sep 29, 2007 11:31 am Post Subject:
So you have three twin and earth cables? Not uncommon.
Were there any short lengths of red core on the old switch, possibly connecting 2 terminals together?
And dont rely on neon screwdrivers - they can be very unreliable, especially testing for dead. Always check with a multimeter or an appliance you know works.
Posted: Sat Sep 29, 2007 11:49 am Post Subject:
Hi
Yes there was a short length of red wire connecting the two comm terminals. Is this correct and how do i rewire the switch taking into account that i have identified the live feed correctly?
Posted: Sat Sep 29, 2007 1:39 pm Post Subject:
Sorry Toto I misunderstood your first post: so presumably you have live/neutral/earth on one cable going into the switch & 1 cable going out to each ceiling rose? If that is the case the red live should be connected to common, the neutral put in a connector with the other 2 black wires, the short link should be connected between the 2 commons, the other 2 reds should be connected to L1( 1 to each switch) & the earth wires to to the earth terminal in the switch box( unless you are fitting a metal faced switch, in which case, the earth terminal on the switch). You also need to do something with the cables that were plastered into the walls. Is it possible for you to replace any screw connectors with crimp connectors & push them up through the ceiling?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
