MagicalTrevor
Joined: 13 Oct 2007 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Sat Oct 13, 2007 12:23 pm Post Subject: Faulty MCB? |
At some point in the last 24 hours my oven has stopped working, dead as a dodo, in addition the spark on the hob has also stopped working. The first thing I did was to check the MCB but it has not tripped. Next I took the oven out and had a quick look, there was no signs of wores burning out or anything like that.
Could this be a problem with my MCB even though it has not tripped?
Thanks. |
ColJack
Joined: 16 Feb 2007 Posts: 7599 Location: West Midlands, United Kingdom Thanked: 129 times
Posted: Sat Oct 13, 2007 3:49 pm Post Subject: |
some MCB's don't always trip externally, the leaver may simply be stuck in the on position.. ( due to non use, or damage from overloading etc.. )
others are designed to only trip half way to differentiate between one switched off and one tripped.. ( though these tend to be the larger industrial types.. )
turn the breaker off ( all the way off.. ) and then re-set it.. |
GRAHAM.ROB
Joined: 13 Oct 2007 Posts: 4 Location: Newcastle upon Tyne, United Kingdom Thanked: 0 times
Posted: Sat Oct 13, 2007 4:54 pm Post Subject: |
Check supply at the switch if its there but not at the oven you have narrowed down the fault If its not at the switchthen check the db |
Steve3948
Joined: 10 Oct 2007 Posts: 144 Location: United Kingdom Thanked: 0 times
Posted: Sat Oct 13, 2007 5:03 pm Post Subject: |
Is this a single fan assisted oven, if so it will be fused down to 13A, behind the oven, or at least it should be.
I have found them connected direct to an outlet plate fed from the cooker and fused at 32A on the FB. |
