DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Electric sockets
This topic originated from the How to page called Installing a power socket
Click here to return to the page called Installing a power socket.
  View previous topic :: View next topic
Author Message
bojitandscarper
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 18, 2007 10:13 am    Post Subject:
Electric sockets
Reply with quote Thanks
Hi I want to fit a new plug socket running the wires from an existing socket on the same wall. The wires from the existing socket come from above the socket, could I run the new wires down the wall and behind the skirting coming back up the wall to the new socket or can I go straight across the wall? icon_redface.gif icon_redface.gif
__________________
Bodge it and scarper
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
DESL
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 18, 2007 10:19 am    Post Subject:
If it's on the same wall go horizontally from accessory to accessory behind skirting board is a no no.
Have a look at this http://www.diynot.com/wiki/electrics:installation_techniques:walls
Back to top
 Alert Moderators
bojitandscarper
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 18, 2007 10:59 am    Post Subject:
Thanx. Also does the wiring which is to be buried in the wall need to be incased in a tube or can it be buried as it is? icon_twisted.gif icon_rolleyes.gif
__________________
Back to top
 Alert Moderators
DESL
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 18, 2007 12:05 pm    Post Subject:
Can be buried in plaster but best use a length of this
http://www.tlc-direct.co.uk/Products/MTOV20.html
Back to top
 Alert Moderators
bojitandscarper
from United Kingdom
Thanked: 0 times
PostPosted: Fri Oct 19, 2007 10:43 am    Post Subject:
Also I wish to blank off the old socket should I use a connector block to.attach the new wires or is there another method? icon_eek.gif
__________________
Back to top
 Alert Moderators
DESL
from United Kingdom
Thanked: 0 times
PostPosted: Fri Oct 19, 2007 1:48 pm    Post Subject:
If you are blanking off the old socket connector block it is ok as long as you leave it accessible by replacing socket with one of these.
http://www.tlc-direct.co.uk/Main_Index/Wiring_Accessories_Menu_Index/White_BG_Index/Blank_Plates_3/index.html
This will also indicate (to some degree) that a horizontal cable is running from old point to new point.
Are you extending ring or spurring from socket?
Back to top
 Alert Moderators
bojitandscarper
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 20, 2007 3:13 pm    Post Subject:
I am spurring from the socket. The old socket is on a ring
__________________
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
no electric to plug sockets 18 2840 Sun Jan 07, 2007 3:52 pm
Electric sockets in Shed 4 440 Wed Feb 07, 2007 9:53 pm
Electric Sockets 450mm high??? 6 520 Mon Sep 19, 2005 5:39 pm
Electric sockets 4 440 Tue Jan 23, 2007 5:45 pm
Correct way to install two electric sockets into shed 5 720 Thu Sep 07, 2006 12:11 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
