DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Replace one button switch with a 2 buttons remote switch??
This topic originated from the How to page called Replacing a one way light switch
Click here to return to the page called Replacing a one way light switch.
  View previous topic :: View next topic
Author Message
michael88
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 25, 2007 3:10 pm    Post Subject:
Reply with quote Thanks
I currently have an old single switch, it has no label, It has a top red wire (so i think its live) and a bottom black cable ( i believe is a neutral) and on the casing its the earth wire which is yellow and green.
I want to install a 2 buttons swith with A & B buttons and I only want to use A for my light and leave out B.
The label on the switch are:
OUT-B OUT-A L-IN N-IN
Can anyone kindly tell me which wire should go where?? DO I have to do some kind of loop wire between OUT-A and N-IN??
Many thanks
Michael
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Thu Oct 25, 2007 3:28 pm    Post Subject:
The black wire in a bog standard normal switch is normally switched live, it should have a red sleeve on it to correctly identify it but is often ommited. Your new switch has a Neutral connection, is this for convenience or is it important to the operation of the switch? If the latter then this will be no good.
I take it that this is some sort of fancy dimmer switch? You can try it connecting one wire to L-In and the other to Out A and see if that works.
Back to top
 Alert Moderators
michael88
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 25, 2007 3:53 pm    Post Subject:
Thanks for the quick reply
I am not too sure what the Neutral is for either, i am trying to get some instruction from the seller, I think its made in china so the terms are a bit different.
I don't get the colour, on the wiki site the colour chart says the Red=Live & Black=Neutral having said that its old, so its pure black no red sleeve like you said.
http://en.wikipedia.org/wiki/Electrical_wiring_(UK)
I wanted to try the L-in and Out-A method as well, but want to get the facts right first, I think my old fuse box use a wire instead just jump off, just don't want to damage anything.
Michael
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Ring circuit and emergency stop buttons on a contactor 16 520 Thu Jul 09, 2009 9:18 pm
Dimmer converted to push-button switch 8 400 Mon May 02, 2005 1:39 am
BLUE BUTTON 9 620 Thu Jul 19, 2007 8:36 pm
Push button MCB's 3 424 Thu May 31, 2007 1:03 pm
RCD test button ineffective 16 740 Sat Sep 22, 2007 8:09 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
