DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
18mm Oak Floor on screed - gaps
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  Bookmark and Share View previous topic :: View next topic
Author Message
gugs
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 31, 2007 12:37 pm    Post Subject:
Reply with quote Thanks
We had 18mm Oak floating floor layed on screed this April. The carpenter used extra strong glue at the joints.
Unfortunately, gaps have appeared at the joints in some areas. In some cases these are up to 5mm wide. They seem worse, near the radiators.
What can we do to remedy this? Is this a continuous process i.e. will the floor settle or will this happen throughout the year during the different seasons? Should we take the floor apart again and glue it to the ground? We went for a floating floor because we wanted to lay underlay. Any advice will be greatly appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gugs
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 31, 2007 12:46 pm    Post Subject:
Sorry forgot to mention
The wood planks are of various length, same width, all T&G.
Back to top
 Alert Moderators
mattysupra
from United Kingdom
Thanked: 18 times
PostPosted: Wed Oct 31, 2007 8:35 pm    Post Subject:
how long after install did the gaps appear? 1Month? or within the last month or two now you have turned your heating back on?
Back to top
 Alert Moderators
gugs
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 01, 2007 8:48 am    Post Subject:
Gaps
Same gaps appeared soon after the floor was layed. However, some large ones in the last few weeks since the heating is on more constantly.
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 83 times
PostPosted: Thu Nov 01, 2007 9:27 am    Post Subject:
How long had the wood been in situ before it was installed? IMHO it looks like the wooden floor was to 'wet' and hasn't had sufficient time to acclimatise before it was installed.
__________________
Voted "Best Flooring Retailer" (1 -2 stores) by Interiors Monthly readers in the 2010 Awards.
Back to top
 Alert Moderators
gugs
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 02, 2007 8:18 am    Post Subject:
How long before layed
The flooring was store in original packing in a heated room from December 2006 until April 2007. The installer, stated it was fine lay it.
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 83 times
PostPosted: Fri Nov 02, 2007 9:18 am    Post Subject:
Stating or really checking the moist content, now there is a difference icon_wink.gif
__________________
Back to top
 Alert Moderators
gugs
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 05, 2007 8:20 am    Post Subject:
Moist
So it appears the flooring was moist when laid. Do you know what is the best remedy now?
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 83 times
PostPosted: Mon Nov 05, 2007 10:22 am    Post Subject:
No, that's not what I was saying, it's very hard to tell now if that had been the case. It sounds like it, based on your story. But if your fitter hasn't checked the moist content before he installed it, it is very hard afterwards to proof it was too moist.
IMHO you've waited too long to get the fitter back, you should have done that the minute you noticed gaps appearing during summer - the season where the air-humidity is normally higher: floors expand then, not shrink!
But see what he has to say?
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
18mm x 120mm oak floor 5 1420 Mon Aug 27, 2007 7:15 am
How to replace 18mm chipboard floor 3 1720 Tue Mar 24, 2009 1:02 pm
Laying 18mm Oak Floor on concrete floor 6 14740 Sun May 21, 2006 8:04 pm
going rate for laying 18mm oak flooring 2 700 Sun Nov 09, 2008 8:15 pm
help! laying 18mm 90mm oak flooring on concrete 7 1760 Wed Feb 18, 2009 9:33 pm
Varme Under Floor Mat Kit 300w 2.0sqm Varme Under Floor Mat Kit 300w 2.0sqm£137.03Varme Under Floor Mat Kit 900w 6.0sqm
Varme Under Floor Mat Kit 900w 6.0sqm£253.49
Varme Under Floor Mat Kit 3450w 23.0sqm Varme Under Floor Mat Kit 3450w 23.0sqm£661.81Varme Under Floor Mat Kit 2550w 17.0sqm
Varme Under Floor Mat Kit 2550w 17.0sqm£561.79
Varme Under Floor Mat Kit 450w 3.0sqm Varme Under Floor Mat Kit 450w 3.0sqm£157.57Varme Under Floor Mat Kit 1050w 7.0sqm
Varme Under Floor Mat Kit 1050w 7.0sqm£280.90
DIYnot
