amj
Joined: 06 Nov 2007 Posts: 4 Location: Berkshire, United Kingdom Thanked: 0 times
Posted: Wed Nov 07, 2007 7:28 pm Post Subject: Separate pump, or all in one unit? |
I'm planning to refurb two upstairs bathromms and want to boost the shower pressure that is currently rather weak gravity fed. What factors should I consider in choosing between (a) box-on-the-wall units with integrated pumps and (b) a separate impeller pump feeding both shower heads? I have a normal (non-combi) boiler, cold water tank in the loft, and HWC next door to one of the bathrooms.
Thanks |
namsag
Joined: 12 May 2004 Posts: 7929 Location: United Kingdom Thanked: 59 times
Posted: Wed Nov 07, 2007 8:34 pm Post Subject: |
Pump in the box units usually have more than enough pressure for most people and cost to buy about £140 from focus etc which is cheaper than you will get it from a merchants.. They are generally quieter in operation than a seperate pump unit and on the whole they are very reliable. Newteam where the biggest manufacturer but have been taken over by bristan |
