amj
Joined: 06 Nov 2007 Posts: 4 Location: Berkshire, United Kingdom Thanked: 0 times
Posted: Thu Nov 08, 2007 12:56 pm Post Subject: What pipework to supply *two* power showers? |
What is the recommended pipework arrangement to supply *two* power showers from the same HWC and cold tank? (They will be the on-the-wall integrated pump type - not a separate impeller pump)
I understand the need to use a surrey/ york flange to provide a reliable how water feed; similarly, a new separate cold water pipe run from the storage tank for the first shower. Can I just tee off those pipes for the second shower?
If I need to provide completely separate pipe runs, how do I get two separate hot supplies from the surrey/ york flange?
Thanks |
Agile
Joined: 26 Jun 2004 Posts: 24311 Location: London, United Kingdom Thanked: 193 times
Posted: Thu Nov 08, 2007 1:04 pm Post Subject: |
Its a bit naughty to call them power showers!
They are just a way to overcome poor head supplies.
The flow rate is usually no more than 10 li/min at best.
Tony |
amj
Posted: Thu Nov 08, 2007 5:17 pm Post Subject: |
Whatever we call them ('integral pump assisted showers' perhaps?) my purpose is exactly what you said - to get a moderate boost to the poor flow I currently have due to a limited supply head.
I'm looking at a Mira model that says it will boost to (up to) 16 litres per minute, which would be more than adequate - I'm not looking for ultimate drenching power!
..... and I still need to find out how to plumb in *two* of them. |
ChrisR
Joined: 24 Jul 2003 Posts: 18665 Location: London, United Kingdom Thanked: 62 times
