BrainyElephant
Joined: 25 Sep 2006 Posts: 6 Location: United Kingdom Thanked: 0 times
Posted: Wed Nov 14, 2007 6:27 pm Post Subject: Noisy Radiators |
Hi! The article says if the flow of water through the boiler is insufficient it can create banging in the boiler. Further, it says it\\\'s important to have correct water-flow rate. But I sometimes have only two (out of seven) of my radiators on, to economise. Does this mean there\\\'s not enough water going through? It does bang! Also, my bathroom (where the header tank is kept) has become incredibly damp. I think this must be due to steam coming out of the header tank (into which I keep hearing water dripping). My bathroom was never this damp until I started economising. Also, I do have corrosion inhibitor in the system, so is there likely to be any damage occurring? Any ideas please? Thanks! |
hi-spec plumbing heating
Joined: 13 Sep 2007 Posts: 1277 Location: Essex, United Kingdom Thanked: 0 times
Posted: Wed Nov 14, 2007 6:35 pm Post Subject: |
sounds like your boiler is over heating and pumping over into the header tank |
BrainyElephant
Posted: Wed Nov 14, 2007 6:38 pm Post Subject: Noisy Radiators |
Thanks ... any idea why? Is it that I don't have enough radiators on? |
Posted: Wed Nov 14, 2007 7:24 pm Post Subject: |
try opening them up
could be many problems for pumping over.
but you should leave the rads on a bit stop the room getting damp etc. |
BrainyElephant
Posted: Thu Nov 15, 2007 10:04 pm Post Subject: Noisy Radiators |
Thanks, I did put them on. The problem seemed solved, and the bathroom has dried out! PHew! Nevertheless, I'm not sure why the boiler didn't like having only two on. Because if I'm at home all day and it's very cold, I don't want heating all over all day, but might want one or two. Having said that, I have now turned some off, so only some (more than two) are on, and it still seems okay. |
Posted: Thu Nov 15, 2007 10:07 pm Post Subject: |
it don't cost any more to have seven on or one. |
patagonia
Joined: 30 Mar 2007 Posts: 126 Location: Hertfordshire, United Kingdom Thanked: 0 times
Posted: Thu Nov 22, 2007 9:07 pm Post Subject: noisy radiators |
Does it really not save money if you turn radiators down/off? If so, what is the point of having thermostatic radiator valves? What about zones? Does it not save money if you turn the upstairs circuit off during the day or have that zone stat at a low setting? |
