DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Stable door
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
chrispriddyuk
from United Kingdom
PostPosted: Thu Nov 15, 2007 9:25 pm Reply with quote
Hi there,
Ive got a wooden stable door to put in as our front door.
It is currently blank and I need some advice on securing it.
Ideally I dont want it to work as a stable, I would have wanted it solid but the style of it was just right and I simply couldnt find it any other way but as a stable door.
So Im thinking I will put a yale lock in the top half
and a dead bolt in the bottom half
and ..... somehow secure the top half safely to the bottom half
Any ideas on this plan?
Thanks all
chris
PS - I would like the front door deadbolt to have the same key as the one for the back doors. I havent got a lock for the back door yet either, where can I buy 3 deadbolts all operated by the same key?
Back to top
 Alert Moderators
HandyHands
from United Kingdom
Thanked: 16 times
PostPosted: Thu Nov 15, 2007 10:47 pm Reply with quote
5 lever BS3621:2004 rated sashlock on the top, and a 5 lever BS3621:2004 rated deadlock on the bottom. Both keyed alike, including the 3rd lock for your back door if required. The two sections are usually kept together with a vertically mounted bolt.
Do not get a yale lock unless you like getting locked out. Have a chat with your local locksmith who'll sort out the above locks for you.
Back to top
 Alert Moderators
freddymercurystwin
from United Kingdom
Thanked: 1527 times
PostPosted: Fri Nov 16, 2007 1:20 pm Reply with quote
I may well be wrong but I believe you can get lock sets called stable door locks which I believe allow you to just be able to have one lock to undo (You still have 2 deadbolts but they're mechanically linked). If they don't make such a thing, well they should! icon_lol.gif . They also lock the two leaves together with hook locks without rattling or unsightly bolts.
Back to top
 Alert Moderators
HandyHands
from United Kingdom
Thanked: 16 times
PostPosted: Fri Nov 16, 2007 6:20 pm Reply with quote
I know these are available for the UPVC versions, not sure about wooden though.
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1273 times
PostPosted: Fri Nov 16, 2007 7:44 pm Reply with quote
couldn't you have got a joiner to make a 'mock' stable door?
Back to top
 Alert Moderators
yandownie
from United Kingdom
PostPosted: Fri Nov 16, 2007 9:51 pm Reply with quote
from an insurance point of view,both leafs should be treated as seperate doors and be fitted with bs3621 rated locks on each as handyhands has suggested.
Back to top
 Alert Moderators
chrispriddyuk
from United Kingdom
PostPosted: Sat Nov 17, 2007 12:01 pm Reply with quote
thanks for posting everyone
It is a wooden stable door so Im not sure that a stable door lock set for going inside the two leaves is avalaible, I have searched though.
I could have got a joiner to make one, but this one was very cheap and with the budget were working too a newly made one couldnt be afforded. good point though.
Thanks for the lock advice.
I will speak to the local locksmith about getting hold of some properly rated locks for the top and bottom leaves.
thanks all
chris
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Where can I get a glazed, single pane, wooden stable door? 3 660 Mon Sep 15, 2008 8:24 pm
Oak Internal Stable Door - where to buy? 3 800 Thu Apr 02, 2009 12:36 pm
Locking 2 sections of stable door 2 80 Fri Nov 25, 2011 10:59 pm
PVC rear 'stable' door - handle/lock replacement? 3 1160 Thu Jan 10, 2008 10:30 am
How many Hinge Bolts on Stable Door 4 1160 Sat Dec 04, 2010 12:55 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
