Have a Whirlpool ADG 7540 Dishwasher that stops after about three minutes, continually beeps with Two Flashes on the LED. Found a small piece of glass in the pump for removing the waste water, however the dishwasher still gives this error. Thanks in advance.
Thanks for such a qucik reply. How does the machine detect water in the base, is there a sensor near the pumps, heater etc? I have run the machine and watched for water but cannot see any leaking through, as soon as the machine goes to empty it sets of the fault?
I have the same problem (F2...) with my Whirlpool dishwasher: ADG6556
and also no water leakage is visible... does someone have a clue how can i fix it ??
Machine is misreporting the fault.
You would have to carry out insulation, short circuit and earth fault testing on component parts to try and diagnose the fault.
Remote diagnosis isn't an option I'm afraid.
