Notso handyman
Joined: 22 Nov 2007 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Thu Nov 22, 2007 2:03 pm Post Subject: Split a Plug socket? |
i have a double plug socket on my kitchen wall and need one on the otherside of the wall in my living room. Can i split this socket somehow into two? One on each side of the wall? |
Diyisfun
Joined: 15 Jun 2004 Posts: 4113 Location: London, United Kingdom Thanked: 9 times
Posted: Thu Nov 22, 2007 2:29 pm Post Subject: |
If you know what you are doing you can leave the double & maybe take a spur from it & have a double in the other side. |
Chri5
Joined: 19 Jan 2007 Posts: 1827 Location: London, United Kingdom Thanked: 28 times
Posted: Thu Nov 22, 2007 2:32 pm Post Subject: |
At the moment the socket in the kitchen should have 2 x cables as part of a ring circuit (check this 1st).
On the assumption that it has, you need to disconnect one of the cables and via a terminal block connector, terminate it inside the back box and extend this cable down to the new socket through the wall.
To complete the ring again, you then need to run another cable between the new socket and the existing socket. This cable will terminate on the socket in the same positions and the cable you removed and extended down to the new socket.
Simple diagram where ----- = wire and N = new socket and O = existing
Current set up -------------O-----------------
To be set up ---------O----------N--------terminal block--------------
Make sure you position the terminal block so that the socket face doesn't foul it when re-fitted, tape it up for safety. |
Steve
Joined: 15 Apr 2005 Posts: 12845 Location: Yorkshire, United Kingdom Thanked: 21 times
plugwash
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Diyisfun
Chri5
