Hello,
I've got a problem with my new electric shower. The old one would sometimes emit warm water but then would trip the circuit after you were soapy. But mostly it just ran cold.
So I bought and fitted a new BnQ essentials 8.5kW one. I got a low power one in case there wasn't enough water pressure for a higher power one. The problem is that in the mornings, on a reasonable temperature it cycles between warm and cold.
I'm guessing that at peak times there isn't enough water pressure to maintain the modest temperature. Even later on in the day there isn't much pressure. The unit is run off the mains, on the third floor, and seems to share its pipe with where you top up the water into the central heating.
Our lodger is moaning about the shower and suggested fitting a pump. Most shower pumps seem to be for mixer showers, and I read that you aren't allowed to put a pump in a mains flow. Is there one I could get? They all seem to be massively expensive, like £300!
Would a more powerful shower help? Or should we just have baths?
Thanks,
George.
Thanks,
George.
