When my heating is on I can't get any hot water.
When my heating is off the radiators seem to have a mind of their own and heat up.
It is then pot luck as to whether I will get any hot water.
In the event of my needing to change the valve can anyone confirm how to drain the central heating on this model of boiler. Do you use the pressure release valve on the bottom left underside as it has a pipe running from it that goes through the wall to the outside?
