Leaking soil pipe vent elbow
16 Dec 2007
Buckinghamshire
Hi (again) all!
It seem that an elbow joint on my soil pipe, just before where it vents to the environment in the loft is dripping.
It's only a few drips a minute, doesn't smell bad, and everything is flushing/emptying at full pace, so I'm assuming it's just condensation or rainwater etc.
What's the correct way to seal this joint properly? I tried self-amalgamating tape but the water got out. I'm loath to duct tape it, unless someone tells me it's a good idea....!
Cheers,
Andy
It's a grey plastic pipe, looks to be push-fit. Having just googled it, should there be a rubber seal that I can replace?
ok you can not buy the seals seperate. but you can change them.
either but a new part and fit or buy a part and just change the seal.
@Bahco - No, the pipe vents out through the top of the roof. There's a hole in the roof in other words, with a raised tile above it.
@sanj.varah - I would do, but it isn't dry enough for the silicone to set... :(
