- Joined
- 28 Jul 2004
- Messages
- 2
- Reaction score
- 0
- Country
This is a variation on a common theme. I\\\'m replacing a bathroom ceiling light with a new one which has a flush plate fitting.
Firstly I made the beginners error of disconnecting the 9 wires ( loop-in ) with out noting which went to the switch. I therefore had to borrow a meter and by checking the resistance and switching off and on the light found out which flex was the switch. One other thing I found was that another flex also gave a reading which I couldn\\\'t understand.
Anyway I wired up according to the diagrams ie 3 live to connecter with no out. 3 earths to connector then out to earth on light. Black ( neutral but not ) from switch to connector then live out to light. Other 2 black to connector then out to neutral to light.
This worked fine. Light goes on with pull cord switching light on and off.
About an hour after installation I went to turn the light on and there was a brief flash then it went out. I assumed the bulb had blown. The weird thing is that when I went to switch the landing light on ( next nearest light ) the bathroom light turned on. I could then turn the bathroom light off from the bathroom and both switches operated their respective lights as normal. That is I was unable to replicate the problem.
Sorry if this is long winded. Any pointers gratefully accepted.
