DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Attatching handrail to newel post.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
Author Message
benjiman
from United Kingdom
PostPosted: Sat Jul 31, 2004 8:55 pm Reply with quote
I am installing new banisters and am currently at the stage of fitting the handrail.
I have bought the handrail fasterners from wickes but when i took the old handrail off i noticed a morticed cut behind the handrail.
It was held in with nails and I have no idea what the rectangular mortice is for. However this means I cant use the fixings that I bought from wickes.
Is there any other way to attatch the handrail so it remains strong and I get a good fit?
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 945 times
PostPosted: Sat Jul 31, 2004 9:37 pm Reply with quote
hellllooo benjamin the mortice is to take a tennon on the end of the
hand rail i prefer to use offset dowels instead of nails
if you havent got enough lenght to cut a tennon and fit it
youll have to fill the mortice with a suitable bit of wood
firmly glued and i would say pegged with a dowel
going through
unless the bracket you have doesnt rely on the repair for
most of its support
you could use screws but this would look naff if done wrong
[i am refering to the repair and assuming wood grain showing]
big all
Back to top
 Alert Moderators
benjiman
from United Kingdom
PostPosted: Sun Aug 01, 2004 7:28 pm Reply with quote
Cheers mate. Think Ill screw in from under the handrail and countersink it. The fillets should cover it after.
Also another quick question.
How do I ensure that the handrail is the same angle as the baserail when fitted on?
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 945 times
PostPosted: Sun Aug 01, 2004 8:38 pm Reply with quote
helllooo benjiman
i assume you mean parralel to the base rail[string as i call it]
have you got 2 g clamps or mastic clamps
mark eccsactly where the under edge of the hand rail will be
clamp on a bit of wood on the inner edge of the bottom newel
sticking out enough to rest the hand rail on make shure
you protect the newel from the other jaw of the clamp
do the same at the top [the top batton will have to be
slightly lower due to the slope]
place the hand rail in situe check its not sagging
[would give you an inacurate angle]
mark bottom end and cut
return to position check a good fit if not recut
when your happy overlap the handrail onto the newel
by about 6mm the go to the top and mark the top for cutting
you should now have a handrail that fits
good luck big all
Back to top
 Alert Moderators
benjiman
from United Kingdom
PostPosted: Mon Aug 02, 2004 2:03 pm Reply with quote
Thanks alot for your help big all. I didnt have any clamps but used wooden battons instead to get the correct angle on the bottom of the handlerail and then just screwed the batton underneath to hold it up in the correct position. Then same with the top. Thanks once again icon_biggrin.gif
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 945 times
PostPosted: Mon Aug 02, 2004 2:48 pm Reply with quote
easy peasy when you know
spindles!!!!!!!!!!!!!!!!!!!!!!!!!!!!
last time i looked it was a ball 100mm across
must not pass through any gap on stairs or
handrails banisters ect
to stop a child falling through
id go for 75 to 100 just even out over
the lenght
dont forget
youve got to add one spacer to the calculation
eg 37 spindles plus 38 spacers
and its the spindle cut at the correct
angle gives you its width on the capping
check frequently to check the spindles
are verticle
check after two thirds to see if have to
tighten or loosen the gaps to fit in
big all
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
STAIRS: Wobbly newel posts, handrail & spindle removal 5 7200 Tue Nov 21, 2006 11:12 am
Replacing and installing newel post 5 100 Wed Apr 11, 2012 10:30 pm
Newel Post Help 2 1060 Tue Mar 18, 2008 2:09 pm
newel post replacement 2 1220 Tue Sep 09, 2008 8:03 pm
How to install newel post (or: fixing prev. owner mistake) 3 12220 Fri Apr 27, 2007 6:44 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
