low water pressure
9 Jan 2008
Glasgow
I have a triton T80SI shower my water pressure is not what it used to be.Can someone tell me how to check if shower is blocked somewhere I stay in cottage flat ground floor Thank you
You will need to turn the water and the electricity off.There will be a compression nut connecting the water supply to the shower.Disconnect the water supply and have a look in the little white plastic pipe theres a filter in there.If you cant move the water supply pipe you will need to take the shower of the wall.
thank you for you reply I am a pensioner but will do my best to try and fix shower i
