Joined: 06 Aug 2004 Posts: 9 Location: United Kingdom Thanked: 0 times
Posted: Fri Aug 06, 2004 12:13 pm Post Subject:
Adding 2 sockets in kitchen
Hi ppl,
I've just moved into a new old house and wish to add another 2 double sockets in the kitchen. There's only one double there already but I don't know if its on the ring or a spur (will check this later). From what I've read so far, if it's a spur then tough but if it's on the ring then it's tough again as you can only have one spur per ring main socket and I want 2
I'm new to this electrics business as you may have guessed...
I suppose i could always extend the ring to the 2 new circuits looping the wire back to the root socket but i'm worried there might be too much cable in the track that i'll have to hack out the wall....
Any ideas?? can i use some sort of fuse with 2 sockets
Posted: Fri Aug 06, 2004 1:29 pm Post Subject:
cheers for the advice....
i'll probably extend the ring, I don't want to start my new house off with bad practices... It may be a slightly bigger trench I have to cut out to fit double the cable but i'm sure it'll be safer in the long run.
Joined: 27 Aug 2003 Posts: 21984 Location: London, United Kingdom Thanked: 78 times
Posted: Fri Aug 06, 2004 2:32 pm Post Subject:
So are you saying, Breezer, that no room should ever have more than one socket circuit?
If there was a spare space in the CU, surely it would be possible to label it so that someone going to it would see "Kitchen Sockets 1" and "Kitchen Sockets 2"?
Or even both just "kitchen sockets"?
If you were so spectacularly challenged that you wouldn't do a proper check, or switch off both just to be sure, you'd probably not think about turning anything off in the first place....
__________________ I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
