DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Wiring diagram for Central heating system
  Bookmark and Share View previous topic :: View next topic
Author Message
stevecarr
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 28, 2008 2:54 pm    Post Subject:
Reply with quote Thanks
Can anybody direct me to a website that shows the wiring diagram for a pumped central heating system, I need to know how?
1 pump
2 boiler
3 room thermostat
3 cylinder thermostat
4 3 port valve (Honeywell)
5 programmers (Drayton tempus7)
Are wired together in the connector blocks.
Problems started when I installed a new tempus7 programmer, whenever I wanted hot water only, I would get hot water but the central heating would also come on, if I wanted central heating only, nothing at all would work.
So I’m thinking the 3 port valve is stuck in the open position, because the little lever on top of the valve is very floppy when I move it, So now I have a new 3 port mid-position valve, but before I install it, I would like the wiring diagram for my system, just to make sure the wiring is correct
thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
uselessFCUK
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 28, 2008 3:29 pm    Post Subject:
__________________
Red to brown, yellow to black and blue to bits!
Back to top
 Alert Moderators
stevecarr
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 28, 2008 6:36 pm    Post Subject:
cheers useless f*****, just what i wanted
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
wiring diagram for heating 6 760 Sun Oct 12, 2008 8:25 pm
FHT floor heating control - mystery wiring diagram!! 6 1700 Sun Jun 01, 2008 9:48 am
Wiring Diagram 2 8400 Tue Jan 03, 2006 12:39 pm
Wiring Diagram question needed answering 7 920 Fri Feb 08, 2008 8:35 pm
Lost my wiring diagram! 2 3200 Wed Dec 28, 2005 10:08 am
Drayton HTS3 Cylinder Stat Drayton HTS3 Cylinder Stat£12.98Drayton Digistat +3 Room Thermostat
Drayton Digistat +3 Room Thermostat£53.84
Salus Cylinder / Pipe Thermostat Salus Cylinder / Pipe Thermostat£8.31Drayton Digistat +2 Room Thermostat
Drayton Digistat +2 Room Thermostat£46.99
Danfoss 102 Mini Programmer Danfoss 102 Mini Programmer£51.88Horstmann Centaurplus C27 Programmer
Horstmann Centaurplus C27 Programmer£24.99
DIYnot
