Crabtree SB6000
22 Mar 2006
West Midlands
Does anyone know if the main 100A switch on an SB6000 can be replaced with an equivalent RCD/RCCB (or whatever the correct terminology is)?
I am advised that we need to add an 'RCD' following the building of an extension.
Is it as simple as that or is a new consumer unit required?
Thanks...
I think Crabtree SB6000 is obsolete, does it have a range name, like "Polestar" or "Starbreaker" or something? Often has the word "Star" in the name.
Do you know how old it is?
Often parts from one Crabtree range will fit another, but you have to check they are identical.
Crabtree SB6000 has screws top and bottom of the MCB (not the "tongue")
I suspect that you are right. It does not show any identifier other than SB6000. According to Crabtree, the units first came out in 1992 but I don't know when they stopped making them. As such, I guess spares may be available for it but I do now wonder if it's time to get a new CU and have something up-to-date. I think the Building Inspector may prefer that, too. For the sake of a 'few quid' (especially after spending thousands on an extension!), this may be a wise option, methinks.
Thanks for your input.
if you do have a new one fitted, consider the use of an RCBO on each socket circuit and shower circuit. It is more expensive than a single RCD but means that you do not lose power on all circuits due to a fault on one. this is safer and much less inconvenient. It enables you to carry on living in your house in comfort while waiting for the fault to be fixed.
You could contact Crabtree and see if they make an RCBO to fit your CU. If they do, it may be double-width which means it would only be suitabe if you had unused space.
