DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
LEAKING OVERFLOW OF BATH
This topic originated from the How to page called Clearing a blocked waste pipe
Click here to return to the page called Clearing a blocked waste pipe.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
DIYBABY
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 19, 2004 7:43 pm    Post Subject:
Reply with quote Thanks
MY BATH OVERFLOW CONSTANTLY HAS A LEAK OF RUNNING WATER. i THINGK IT IS PLUMBED INTO THE WASHING MACHINE AS THE WASHING MACHINE FACES THE WALL OF THE BATH AND THE KITCHEN SINK IS ON THE OTHER SIDE OF THE KITCHEN. i DO NOT HAVE EASY ACCESS TO THE BATH...HELP
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Graeme
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 19, 2004 9:14 pm    Post Subject:
You have no option but to take off the bath panel and see whats behind there. I have never heard of a w/m being plumbed into bath pipes before! The overflow will only be connected by a hose leading below the plug hole, so water would be coming out of there long before the overflow.
__________________
Life expectancy would grow by leaps and bounds if green vegetables smelled as good as bacon
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Thu Aug 19, 2004 9:53 pm    Post Subject:
Without seeing it I advise purchase a new bath overflow and trap and connect it to waste pipe soley dedicated to the bath.
The W M hose should plumb onto a sink waste (that has a WM spigot) and it too needs a separate waste pipe.
Both wastes will now discharge into the gully and should solve your problem. icon_biggrin.gif
Keep us posted
__________________
85 weeks without smoking!
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Fri Aug 20, 2004 12:25 am    Post Subject:
Hardly likely to be the WM causing a CONSTANT leak surely? More likely the WC overflow is conected to the bath o/f and the washer's gorn?
Back to top
 Alert Moderators
DIYBABY
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 20, 2004 4:58 pm    Post Subject:
There is no space for washing machine on sink side of th ekitchen. The overflow must be connected to the washing machine otherwise the water would come out of the bath plughole first...worrying. I havn't used the washing machine yet (new flat) and am now worried to
Keep us posted
Back to top
 Alert Moderators
Graeme
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 25, 2004 5:06 pm    Post Subject:
see option 1!
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
LEAKING OVERFLOW ON BATH 3 680 Wed May 18, 2005 11:52 am
Leaking overflow on P-Bath 5 440 Tue Apr 03, 2007 10:15 am
LEAKING BATH OVERFLOW 2 440 Thu Dec 28, 2006 2:03 am
leaking bath overflow 2 460 Fri Jul 27, 2007 9:58 pm
Neighbours overflow Pipe leaking constantly 7 900 Fri Nov 25, 2005 4:32 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
