ch not obeying thermostat
20 Nov 2002
G'day, I've a Stelrad Ideal Classic NF40 boiler with a Honeywell ST6300A programmer & H/well T40 t/stat in the lounge.The ch comes on at the right times, cuts out as you'd expect but then refuses to come back on other than by turning the boiler off & on. Anyone know what's playing up ?
Either you room has reached temperature that the thermostat is set at or more probably duff thermostat.
Cheers Anon , I was pretty (years ago) much set on that but also wondered if a heat sink effect might mess up the settings as t/stat
is on wall between neighbours even though the air temp. is obviously well below the t/stat setting.
I also have a Stelrad Ideal Classic boiler and have the same problem. Have you managed to resolve the problem, if so how??
Cheers
sorry, thought this was dead in the water. turned out boiler PCB was fragged. Fine & dandy once new one fitted.
