upvc door lock problem
22 Feb 2008
Kent
Hi all
hope someone can help.
I went to lock my door today and the Handle will not go up to allow me to turn and lock the door.
I have tried it with the door open and still does not work.
Any Suggestions as to what has caused this to happen all of a sudden.???
Many Thanks
katy
has the sliding wedges on bottem of door frame moved causing door to drop slightly in turn causing locking mechanisim not line up
Only time I've come across this problem was on a set of french doors fitted with a multipoint mechanism. The mechanism had extensions top/bottom which fired bolts into the frame. These had gradually seized (rusted actually due to rain getting into the mechanism), and needed stripping down and lubricating.
Try a squirt of WD40 and work the mechanism up/down.
