DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Increase size of cold water storage tank
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Bankrobber
from United Kingdom
PostPosted: Tue Feb 26, 2008 8:56 pm Reply with quote
Hi
In want to increase the size of my cold water storage tank as it occaionally runs dry due to my shower pump. Can I just add an additional tank purely to feed the cold water to the shower pump, fed by teeing of the mains water pipe, additional ball cock etc or can I add an additional tank and join both tanks together at the bottom? Which is best?
Back to top
 Alert Moderators
doitall
from United Kingdom
Thanked: 1536 times
PostPosted: Tue Feb 26, 2008 9:16 pm Reply with quote
Best to link the two together.
You have to take the cold mains to the ballvalve in the first tank, and the outlets in the second tank, with a link between the two tanks.
Back to top
 Alert Moderators
Bankrobber
from United Kingdom
PostPosted: Tue Feb 26, 2008 9:23 pm Reply with quote
OK thanks for that.
So I would be best repacing the original tank with a bigger one rather than adding a second tank?
I was trying to find an easier option!
Back to top
 Alert Moderators
doitall
from United Kingdom
Thanked: 1536 times
PostPosted: Tue Feb 26, 2008 9:53 pm Reply with quote
Bankrobber wrote:
OK thanks for that.
No you can link the two together, you need a flow through the tanks otherwise one will stagnate
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Can I increase the size of my mains water pipe? 12 1360 Tue Apr 19, 2005 5:36 pm
Increase pipe size? 7 180 Tue Dec 14, 2010 5:13 pm
8mm--10mm pipe size increase 2 260 Fri Sep 10, 2010 8:39 pm
moving the cold water tank to increase preasure 8 1560 Wed Sep 24, 2003 11:50 am
Tap off water tank - increase pressure - etc validation 9 1100 Tue Jan 01, 2008 6:03 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
