Hot water runs slow
27 Feb 2008
When I first moved into the house the hot water had excellent pressure, 4 years later I'm finding that the hot water comes out at first with excellent pressure, but then drops off and steadily becomes a trickle... for example, running the bath is fine for the first 30 secs, and then if I turn the sink tap on it will stop the bath taps from running, and I find when showering I keep having to turn the hot tap up until it is nearly on full just to balance with the cold, I have noticed too that the hot water has got VERY Hot over the last few months!!
Can anybody advise me what to do to get the pressure back?
Sorry for the delay in getting back!
My boiler is an Ideal Classic Se18FF
and the Central Heating tank is an Megaflow Heatrae Sadia
As I mention it is not until recently it has started to run slow after a couple of minute
Cheers
When you open the taps and get lots off pressure, and this drops its probably a filter blocked. You need to find the fillters and than clean them try this
I think the pressure reducing valve on a mega flow has a filter in.I m not sure , i need to check over some gumf
Cheers Andy, my next question was going to be where do I find the filters lol!!
It should be on the the mains water pipe entering the megaflow.
Basically a brass thing with a black plastic cap on.
Isolate the water first, unscrew this with a bucket underneath. remove the filter and clean under running water.
Sometimes the double check valve gets stuck. give this a tap with something hard or replace it.
You might want to find a picture off a reducing valve first on the internet before you get started.
