john90
Joined: 03 Jan 2007 Posts: 62 Location: London, United Kingdom Thanked: 0 times
Posted: Wed Mar 12, 2008 9:22 am Post Subject: Boiler noises |
Hi all,
I have a Glow-worm Compact 80E that has started to make some strange noises. When you turn on the CH or DHW I hear a noise from inside the boiler that sounds like an hydraulic lift or maybe a electric drill or saw. Once the CH or DHW is turned off, the noise can still be heard for a few minutes. Sometimes the system does work as normal (without the strange noises). I know its not the best description but any ideas what the problem could be ? Heating / DHW working fine but I don't want to wait until the system breaks down before getting some advice.
John. |
LUNAT
Joined: 10 Jan 2008 Posts: 475 Location: United Kingdom Thanked: 3 times
Posted: Wed Mar 12, 2008 8:33 pm Post Subject: |
HI
1.pump partially blocked
2.boiler stat faulty which can cause boiler to overheat and pipes to rattle or bang |
john90
Posted: Wed Mar 12, 2008 10:48 pm Post Subject: |
thanks, to unblock the pump, would it be worth draining / cleaning the system or just try to bleed it - thanks again
also, the noise is comming from inside the boiler, not any of the pipes. I can hear it now, sounds like a loud dentists drill |
LUNAT
Posted: Thu Mar 13, 2008 4:57 pm Post Subject: |
HI
you can buy sludge remover /central heating cleaner for heating systems
which should eliminate few problems .scale buildup,etc. |
