Hi guys,
Wondering if someone could offer a bit of advice as I'm worried about my boiler.
I have two and a half year old house with the original heating system:
Boiler make model:
IDEAL Classic/SE9FF
The system is one of those whereby I have a bolier unit downstairs and a storage tank for hot water. (no idea what they call these)
I know the boiler will probably be due a service soon as I've been in the house for just under a year (I've no idea of the previous occupants history with the system or if they had it serviced at all)
Now to the issue:
Just recently, the boiler takes about 2-3 attempts (sometimes 4) attempts to spark up when the thermostat kicks in. I hear the click of the thermostat and then the ignition of the gas (that 'whoomph') but then it does the same thing (up to four times sometimes) ?? Sometimes it can happen mid way through the boiler working!! It clicks and I hear the ignition of the gas - but it seems like it was already running so why ignite in that way??
This is the central heating by the way..I've no idea if it does the same when the water kicks in at around 4am as I'm asleep
I just wanted to ask you fellas in the know if this seems like a serious problem? The heating is all working fine at the moment apart from this weird ignition behaviour.
As I said above, I know the system is due a service, but I just want to arm myself with some info incase I get stung by some unscrupulous 'Rogue Trader'. I'm a single bloke living on my own and money is tight but I have no quibble forking out for repairs if justified.
Cheers for any responses - they would be much appreciated.
Boiler make model:
IDEAL Classic/SE9FF
Now to the issue:
