DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Leaking cistern since syphon changed!!!!
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
stevehayes
from United Kingdom
PostPosted: Sat Mar 22, 2008 3:39 pm Reply with quote
can i just ask if anyone knows what i should do in this situation: last week i changed the syphon on my cistern, but when i attached the cistern back onto the pan (close coupled) a little bit of water comes through (the wing nut holes) when i flush the cistern. it's not much, but adds up over the course of the day. do i need a new donought washer (like-for-like one). the thing is, this wasn't leaking before i changed the syphon so how comes it is now!!!! weird or what?!!
Back to top
 Alert Moderators
giblets
from United Kingdom
Thanked: 405 times
PostPosted: Sat Mar 22, 2008 3:55 pm Reply with quote
Not weird at all. Unlikely you would get the existing donut washer to fit back in exactly the same position and it would have compressed over the years. Always change the donut washer if you have to remove the cistern.
Back to top
 Alert Moderators
stevehayes
from United Kingdom
PostPosted: Sat Mar 22, 2008 4:13 pm Reply with quote
thanks for your advice. much appreciated! i heard somewhere a while back that plumbers putty can also help a donought washer to make a better seal?!! is this worth a go?
everytime a cistern is removed from the pan, a new donought should be replaced then ... good advice there, thanks again. Although actually saying that-i changed my nan's syphon about 6 months ago, and the donought didn't leak like my one does now!!! is it just out of good practice to replace it with the syphon anyway??!!
Back to top
 Alert Moderators
giblets
from United Kingdom
Thanked: 405 times
PostPosted: Sat Mar 22, 2008 4:27 pm Reply with quote
Don't use the putty - it will make matters worse. You would have to take the cistern off again to apply it so why not fit a new donut instead.
Methinks you may have been lucky with your Nan's cistern.
Back to top
 Alert Moderators
stevehayes
from United Kingdom
PostPosted: Sat Mar 22, 2008 4:45 pm Reply with quote
so if a plumber comes to a house to change a syphon and removes the cistern, how do they know what type of donought washer to bring with them 9as there are many different sizes)!!! surely they don't go down to the plumbers merchant and leave someone's toilet apart?!!!!
Back to top
 Alert Moderators
gigz
from United Kingdom
Thanked: 513 times
PostPosted: Sat Mar 22, 2008 4:50 pm Reply with quote
Sometimes we have to,(theres only a few different types and some are universal). Take your dounut to a plumbers merchant and they will replace with a new one of the same shape/thickness.
Back to top
 Alert Moderators
stardanny
from United Kingdom
Thanked: 187 times
PostPosted: Sat Mar 22, 2008 4:51 pm Reply with quote
I do keep a few washers in my van. One size fit most of it, sometime with silicone sealant as a last resort.
Dan
Back to top
 Alert Moderators
stevehayes
from United Kingdom
PostPosted: Sat Mar 22, 2008 5:03 pm Reply with quote
ok thanks for help all. i will go to plumbers merchants on tuesday to get a new donought once and for all!!! on another note, are push-button valve's (dual flush) standard sizes/heights and can they easily be changed/replaced if falty like a tradkitional syphon can - as i'm thinking of having a push-button cistern downstairs..
Back to top
 Alert Moderators
JPC
from United Kingdom
Thanked: 20 times
PostPosted: Sat Mar 22, 2008 5:47 pm Reply with quote
no- normally like for like is required
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Leaking kitchen mixer tap - changed 'o' rings still leaking 9 3260 Thu Jun 26, 2008 9:50 am
CHanged a TRV by creating a vacuum - a few things..... 5 1140 Wed Jun 25, 2008 11:49 am
Changed a radiator, now no CH? (Fixed) 12 840 Fri Mar 21, 2008 9:43 pm
Water meter changed today but now no hot water?? 7 760 Mon Feb 25, 2008 6:57 pm
Changed washer - now boiler won't work 3 460 Thu Sep 20, 2007 2:53 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
