Is my Baxi 105HE Instant realy loosing water ??
29 Jun 2006
Lancashire
Have a problem with my father in laws 105 HE Inst ( i know go on, get over the laughing fit) Anyway, loosing presure, or is it ?
The gauge is reading 0 so top it upto 1.5 and away it goes. 10 mins later 0 again. I noticed their was a slight drip for the relief valve so i twisted it till it let water pass then let go to dislodge any ****e that may have been preventing a seal.
Fired up the boiler for another 10 mins. Noticed it was still dripping so the valve was replaced. The pressure issue is still the same BUT i have noticed the boiler still runs ok and heats the rads ok even with no pressure.
Also, if i top up to 1.5 bar, once the boiler fires up and runs for 10 mins or so the relief valve dumps a load of water out? Could this be simply a faulty gauge ? and its reading low so i am over filling the system and the valve is dumping excess pressure ?
cheers clf-gas.
is there a way of checking this without replacing the gauge ? Or would you simply fit a new one and have done with it ?
Baxmax,
The boiler is just under 2 years old, would you expect a problem with this so soon ?
Am i looking for a leak ?
I had a light bulb in one room in our house that lasted 12 years,whilst in another room the same model and make of light bulb only lasted two months :eek:
baxi have had a problem with expansion vessels on instants, isolate boiler dump the pressure and pump expansion vessel up to 1 bar then open isolating valves and set system pressure to 1bar
There is a chance it may be the secondary heat x :(
Cheers bax. Very helpful thanks.
I shall tell him to get a boiler guy in. I aint messing with it.
