DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Wylex MCB
This topic originated from the How to page called Miniature circuit breakers (MCBs)
Click here to return to the page called Miniature circuit breakers (MCBs).
  View previous topic :: View next topic
Author Message
Fortha
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 06, 2004 10:39 am    Post Subject:
Wylex MCB
Reply with quote Thanks
I\\\'m an eager (some may say ignorant) novice trying to add two new MCBs to my exiting Wylex consumer unit for the purpose of accomodating new appliances in a kitchen. The existing MCBs are Wylex type 2. I have found various references to Type B and Type 16 but none for Type 2 and no pictures that look the same as my existing MCBs. Can the Type B & 16 be used in my consumer unit? Any advice would be welcome and I can supply photos if necessary. icon_question.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Mon Sep 06, 2004 10:45 am    Post Subject:
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Mon Sep 06, 2004 10:47 pm    Post Subject:
Re: Wylex MCB
There's no such thing as a Type 16.
What you've seen reference to is a 16A Type B.
What are the appliances?
What rating are they?
Do you know what size cables to use?
Why do you need/want two circuits?
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
kai
from United Kingdom
Thanked: 5 times
PostPosted: Thu Sep 09, 2004 9:09 pm    Post Subject:
Wylex
Try putting a photo of the consumer unit here...
Here's mine - containing two new B16Amp MCB's in it - can you spot them?
then someone could probably identify it for you.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Thu Sep 09, 2004 9:13 pm    Post Subject:
kai can i ask why it has two main switches and no rcd?
to the original powster we really need to see the actual breakers exposed to give you more info
Back to top
 Alert Moderators
kai
from United Kingdom
Thanked: 5 times
PostPosted: Thu Sep 09, 2004 9:21 pm    Post Subject:
Third floor flat
This was originally installed by the builder in the Nineties, and is in a third floor maisonette, the left hand side is the economy seven supply, and the 32a ring main's RCD's are mounted elsewhere outside the consumer unit.
Back to top
 Alert Moderators
enjay
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 02, 2004 6:08 pm    Post Subject:
I think the Wylex MCB you require is the NB version as they have Type 2 on them and picture on Fuse Company website looks same as mine (I have same problem as need to add Cooker to spare slot in box).
http://www.thefusecompany.com/index.php
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Sat Oct 02, 2004 10:03 pm    Post Subject:
tlc stock NB breakers for NN consumer units
Back to top
 Alert Moderators
Sean'y w
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 19, 2007 5:58 pm    Post Subject:
the Type B refers to the MCB's charicteristics, for domestic installations you will always use a type B (or Type 2 if your stuck in the past) icon_smile.gif other type's are for spacific jobs, IE motors on factories n stuff
getting an mcb to fit your board isnt hard, your best bet is to go to a electrical howlsalers and talk to them, it would be handy if you could take one of ur exeisting breakers along with you,
you can make other breakers fit your board but this is a bit of a bodge i have done it in the past but i am an electrician,
make sure you get the right breaker for the cable size
2.5 radial - 16Amp or 20amp MAX
2.5 Ring 32Amp (there must be 2 cables going into the breaker)
4mm radial- 32Amp
if you need any more info let me know.
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Sat May 19, 2007 6:03 pm    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Wylex consumer Unit 8 360 Sat Jul 05, 2008 12:41 pm
WYLEX WSES 80/2 RCD 7 1060 Sun Jun 01, 2008 9:50 pm
Wylex Upgrade 30A to 45A needed or not? 45 1820 Thu May 08, 2008 8:52 pm
Old Wylex fuses - Help!! Update ***Sorted :)*** 15 780 Sun May 04, 2008 1:44 pm
Wylex consumer unit screws 12 520 Fri Jul 11, 2008 6:27 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
