john90
Joined: 03 Jan 2007 Posts: 62 Location: London, United Kingdom Thanked: 0 times
Posted: Wed Apr 09, 2008 8:18 am Post Subject: no water from all hot taps |
hi, a friend of mine has a indirect system. CH is fine but he has no water at all coming from any of his hot taps. I haven't seen his system as he only called me last night. I also do not know how long he has had this problem. I'm not sure what the problem is, possibly the float valve in the cwsc... is there anything else i should consider
thanks for your time folks
John. |
Whitespirit66
Joined: 15 Dec 2007 Posts: 497 Location: Bristol, United Kingdom Thanked: 6 times
john90
Posted: Wed Apr 09, 2008 10:36 am Post Subject: |
as i've said above, "I haven't seen his system as he only called me last night" I'm just looking for a few suggestions as to what the problem could possible be, not an in depth analysis |
Goldspoon
Joined: 20 Jan 2008 Posts: 752 Location: Anglesey, United Kingdom Thanked: 9 times
Posted: Wed Apr 09, 2008 2:33 pm Post Subject: |
If he has no water at all...
Airlock between cylinder and taps.
Cylinder empty caused by inlet pipe blocked/switched off at gate valve (tap). |
john90
Posted: Thu Apr 10, 2008 8:01 am Post Subject: |
Thanks for you advice Goldspoon, we'll check for both. Thanks again. |
