diagnose my over pressure in heatline combi
17 Apr 2008
Nottingham
tired of so-called plumbers and heating engineers wanting to change parts on my boiler till its fixed!!
the syptoms:
pressure rises into red consistently with time within 15 mins, then blows off through pressure relief valve,resulting in boiler shut down when cold.
pressure does not rise when cold- so ive dismissed 1 engineers idea to change filling loop.
blow off valve only operates when pressure of system in red and 3bar +- so again ive dismissed changeing this- as in my mind its operating as norm
expansion vessels have been mentioned to me but cannot be explained to me how to test, what the pressures should be when hot and cold- all ican get is shrug of shoulders when i ask them to test it.
the system has been installed 5 years, theres always a build up crap around the internal of taps, from reading on here, systems need to be flushed????
please advise as very wary of engineers that fill me with no confidence,
kind regards,
tommy 07971 978044
Pressure vessel will most likely be the answer..
you will see a valve on the vessel like a tyre valve. If you push the pin in like your letting a tyre down then if you get water come out then its split inside,, if you dont get water then it needs pumping back up to the requited pressure which will be in the manufacturers instructions ..
thanx for the reassurance men- 1 hour on- ive hooked up my battery breakdown pack, that allows u to pump ur car tyres up, walered 10 psi in, it is acting differently but early days.
ive read further into this system flushing- and im interested- can any 1 tell me how to inject into the system- i dont fully understand the reference to adding it through the expansion vessel-so please be obvious-could i jus put a powerball into the highest radiator,- dont laugh- it works a treat on cars- if any1thats responded wants help/advice on there vehicle probs- please dont hesitate to call- - and then id have to repressurise the system/ bleeding thoroughly / balancing- again please be obvious- i have only the experience that ive gained by talking to ejits, and spending 25mins on this website-(not ejits), kind regards, woody 07971 978044
You can get the stuff that comes in a tube and you use a silicon gun to inject into a rad via the bleed nipple,, instructions will come with the tube which you can get from a plumbing supplies ..
Oh and unless you know about FTO's then you aint touchin my car :LOL:
job seems to be a fish now men- heating engineers- ive **** em better round where i live- thanx for ur help. kind regards, tommy
kind regards,
tommy 07971 978044
Its better to get a boiler engineer rather than a general plumber!
The best are confident of their diagnostic skills and will offer a no-fix no-fee!
Tony
