Hi
i am the unfortunate owner from new of the above boiler which is now approx 13 years old.
First problem was the thermo coupling/er (would not ignite and stay lit) new one replaced problem solved.
New problem, the pilot light is lit, the honeywell controls are lit, telling me the central heating is on, but the rads are cold as ice. Thermo stat in hallway is calling for heat but its not coming on.
When i've clicked c heating on, the actual boiler does not make the usual 'whooshing' sound as if it's firing up.
I have run upstairs to check the pump in tank cupboard, it is vibrating/on, this also works for the hot water.
Now do i cut my losses and invest in a new boiler, and what exactly is this boiler, ie, combi etc. And what type should i be looking at if purchasing a new one and roughly what price.
replies would be most appreciated.
jackjack
also should mention that when rads (when working!) Are off the water is red hot, when water and rads are both on the rads are only warm and the hot water is just 'hot' not boiling. Is this significant
jackjack
