| Author |
Message |
robsant
Joined: 07 Aug 2007 Posts: 19 Location: United Kingdom
Posted: Mon Apr 21, 2008 8:38 pm |
I have been advised to have a Vaillant Ecotec Plus 937. Should i make sure the Vaillant VRC 400 weather compensator is fitted at the same time?
The boiler will be in the center of the house, so not near an outside wall, so will that make it difficult to fit the outside sensor? i guess it could go to the roof where the flu will go but that is 4 meters away vertically.
Finally please can someone explain exactly what the weather compensator does.
Thanks,
Rob |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
WDIK
Joined: 15 Dec 2007 Posts: 4864 Location: Nottingham, United Kingdom Thanked: 55 times
Posted: Mon Apr 21, 2008 9:24 pm |
a compensator looks at the room temp, the outside temp and the set temp.
it the then calculates usually by learning from the Q factor of your home just what temperature to have the flow at using a multi variable algorithm based on learned data, as to how long it takes your home to achieve the set point.
in doing this it will instruct your burner to modulate till the desired flow setpoint is achieved.
in buildings with a very high Q often the outside sensor has little value.
optimisation is achieved by switching off in advance on a precalculated drop of say 1/2 degree in the last hr, and switching on to achieve a set temp at the set time according to inside and outside temp.
gives greater climatic control of both comfort and efficiency. |
| Back to top |
howy1
Joined: 20 Oct 2006 Posts: 275 Location: Norwich, United Kingdom
Posted: Mon Apr 21, 2008 9:29 pm |
Hello , i had a weather compensator installed with my boiler and i am not convinced it was a good route to go , the other day it was 11 degrees outside and my rads were red hot , also i expected better gas bills but they have not materialised . You dont feel like you have any control of the system as an end user either , so tred carefully . |
| Back to top |
WDIK
Posted: Mon Apr 21, 2008 9:31 pm |
| howy1 wrote: | | Hello , i had a weather compensator installed with my boiler and i am not convinced it was a good route to go , the other day it was 11 degrees outside and my rads were red hot , also i expected better gas bills but they have not materialised . You dont feel like you have any control of the system as an end user either , so tred carefully . |
usually that because its been set up incorrectly
they do work they are my bread and butter  |
| Back to top |
simond
Joined: 26 Oct 2004 Posts: 3980 Location: Surrey, United Kingdom Thanked: 258 times
Posted: Mon Apr 21, 2008 9:37 pm |
Weather Comp varies the flow temp of the radiator water based upon the outside temperature.
The ratio between the two is set by a multiplier, based upon the insulation value of the property.
There is also an algorithm as the response is not linear, but we don't need to understand this. Some WC allow you to change the curve of the response.
If your property is uniformly insulated (either well or badly) WC can save energy by running the boiler in condensing mode for longer periods.
The Vaillant VRC430 is the new WC controller, the old VRC400 is a pain to use. The distance of the sensor is not too much of an issue as long as the cable is sized to prevent a significant volt drop.
The respondent saying his WC is no good will have the wrong response curve set in the memory, or a house with widely varying insulation values across different rooms.
| Back to top |
tonybhoy
Joined: 15 Jan 2008 Posts: 5842 Location: Glasgow, United Kingdom Thanked: 535 times
| WDIK wrote: | | howy1 wrote: | | Hello , i had a weather compensator installed with my boiler and i am not convinced it was a good route to go , the other day it was 11 degrees outside and my rads were red hot , also i expected better gas bills but they have not materialised . You dont feel like you have any control of the system as an end user either , so tred carefully . |
Been trying to push them on Valliants but people don't like the sound of them running the heating system.
Personally I would have one in a minute,anything that can save even more money on fuel bills is got to be worth considering.
However WB CDIs are not set up for them software wise according WB tech.Not that I have a WB CDI  |
| Back to top |
WDIK
Posted: Mon Apr 21, 2008 9:49 pm |
| tonybhoy wrote: | | WDIK wrote: | | howy1 wrote: | | Hello , i had a weather compensator installed with my boiler and i am not convinced it was a good route to go , the other day it was 11 degrees outside and my rads were red hot , also i expected better gas bills but they have not materialised . You dont feel like you have any control of the system as an end user either , so tred carefully . |
personally i have a 2005 greenstar 30he wonder if you can tell me, i fitted the tr2 room sensor and remote, it has its own opt comp, does it allow an outside sensor? is it a 10k?
sorry the wife lost the manual  |
| Back to top |
howy1
Posted: Mon Apr 21, 2008 9:50 pm |
Simond , maybe you summed it up when saying there are wide variations in insulation , house`s especially older ones may not be condusive to WC . |
| Back to top |
WDIK
Posted: Mon Apr 21, 2008 9:53 pm |
| howy1 wrote: | | Simond , maybe you summed it up when saying there are wide variations in insulation , house`s especially older ones may not be condusive to WC . |
that the Q |
| Back to top |
tonybhoy
Posted: Mon Apr 21, 2008 10:00 pm |
| WDIK wrote: | | tonybhoy wrote: | | WDIK wrote: | | howy1 wrote: | | Hello , i had a weather compensator installed with my boiler and i am not convinced it was a good route to go , the other day it was 11 degrees outside and my rads were red hot , also i expected better gas bills but they have not materialised . You dont feel like you have any control of the system as an end user either , so tred carefully . |
WB don't do WC according to their tech guys.
Apparently the PCBs on WB don't have software written that allows WC and according to WB there is no demand for it
Give them a phone and ask,
01905754624 |
| Back to top |
WDIK
Posted: Mon Apr 21, 2008 10:05 pm |
then i just have a compensator wb |
| Back to top |
WDIK
Posted: Mon Apr 21, 2008 10:06 pm |
if you need or want an opt comp have a few coster units kicking around
955 611's |
| Back to top |
doitall
Joined: 08 Jan 2005 Posts: 16710 Location: Bath, United Kingdom Thanked: 1130 times
Posted: Mon Apr 21, 2008 11:11 pm |
Servowarn (honeywell) have been making WC's for years, mine is 26 + and has saved thousands on the fuel bill
Highly recommend if your guy knows how to set them up. |
| Back to top |
D_Hailsham
Joined: 18 Oct 2007 Posts: 7727 Location: Sussex, United Kingdom Thanked: 717 times
Posted: Tue Apr 22, 2008 10:42 am |
| WDIK wrote: | a compensator looks at the room temp, the outside temp and the set temp.
Q Factor is a new term to me in relation to buildings. I know what is meant by the Q of a tuned circuit in Electronics; but can't see how this can be applied to a building.
Please enlighten me.  |
| Back to top |
Agile
Joined: 26 Jun 2004 Posts: 46547 Location: London, United Kingdom Thanked: 2570 times
Posted: Tue Apr 22, 2008 11:05 am |
I have not heard that term used for buildings but is quite a good analogy to a tuned circuit.
It is in "simple terms" related to the thermal mass of the building, the radiator output power and the heat loss of the building.
Easier to "learn" than calculate!
Tony |
| Back to top |
