Indesit w123 not moving through cycles
13 Sep 2004
Hi guys
When put Indesit 123 on wash cycle, continues working but selector just stuck on that part of cycle until reset & move on manually. If set to drain or rinse cycle there\\\'s no problem there...it moves on to end. Hope this is enough info.
Any help much appreciated.
Cheers
let me guess, you put clothes in, shut door start prog,fills up, it tumbles around a bit then sits there?
if so its your heating element that has given up the ghost
Hi Breezer
It fills up & tumbles fine, but just keeps on going and going without the selector dial moving....m/c doesn't stop...would go on if don't reset and move to another programme.
Appears to be only filling with cold water so tried changing round hot & cold water inlet pipes and then only fills with hot water....does this mean the hot water inlet valve needs replacing or is this not relevent?
it does indicate only one valve is working, i would get it changed as soon as, but i still suspect the heater, but get new valve first
