mattylad
Joined: 26 Apr 2008 Posts: 2479 Location: Lancashire, United Kingdom Thanked: 9 times
Posted: Sat Apr 26, 2008 11:31 pm Post Subject: Saniflo non return valve? |
Hi, shortly after moving into a house with a Turboflush macerator, it started to keep turning on/off every 20 seconds or so.
Then when powered down the toilet will fill with water after it has been used
(its coming back down the pipes).
Now I have had the non return valve off and I suspect this is the culprit.
Mainly because it has a hole in it.
but I have seen holes in rubber before & this is not a natural hole, it is a perfect man made punched hole.
Any reason it would be like that?
And any suggestions where I can obtain a new one thats not going to be damn expensive.
Cheers,
Matty |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Sat Apr 26, 2008 11:32 pm Post Subject: |
have you tried the big places like travis perkins, plum center or google? __________________ Do you like music Mr Finch?
Forum = Opinions |
mattylad
Posted: Sun Apr 27, 2008 12:12 am Post Subject: |
tbh I have not, I tried the engineer that last replaced it, but he wanted £27 for what appears to be a £4 part, that he last replaced 3 months before it failed.
I di look on google but did not find anything that matches it.
More concerned over why the hole would be man made though.
Cheers. |
breezer
mattylad
Posted: Sun Apr 27, 2008 10:32 am Post Subject: |
Did you forget to add a comment there Breezer?
Or are you insinuating that the guy that replaced it deliberately put something that will fail in? lol (thats what I think). |
breezer
Posted: Sun Apr 27, 2008 11:13 am Post Subject: |
nope, that was it. and yes i am doing what you said. __________________ Do you like music Mr Finch?
Forum = Opinions |
Agile
Joined: 26 Jun 2004 Posts: 24304 Location: London, United Kingdom Thanked: 191 times
Posted: Sun Sep 07, 2008 10:56 pm Post Subject: |
if its a Turboflush then the thread heading should say that!
If they are pumping up a small distance or a larger distance the the supplied flap NR valve is woefully inadequate!
I fitted one to pump up via the loft to the drain on the other side of the house. It had the same problem as you did.
I solved the problem by fitting a rare 32mm non return valve which was fully water tight. But I dont remember where I got it from, possibly from BES.
Tony |
