DIYnot
Local | Network
   DIYnot > Forums
Local | Network
removing dried excess grout from ceramic floor tiles
This topic originated from the How to page called Ceramic floor tiles
Click here to return to the page called Ceramic floor tiles.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > General DIY
Author Message
ftlpaul
from United Kingdom
PostPosted: Mon Apr 29, 2002 3:25 am Reply with quote
Myself and a few friends were helping some other friends grout ceramic floor tile in their new home. This was my first time doing it and the ones who were applying the grout got a bit carried away and did it faster than those of us who were cleaning the wet grout off the tile could keep up. To make a long story short, the grout started drying faster than we could clean and now there is a lot of excess grout, both thin streaks and lumps of it that have dried on much of the tile. I believe it was a polymer based grout and we had to mix it ourselves. Now that it's dried, how can we remove the excess grout from the tiles?
Back to top
 Alert Moderators
Guest
PostPosted: Mon Apr 29, 2002 11:23 am Reply with quote
To remove the dried grout use a soft wire wall, ensure it wont scratch the tiles on a spare tile and go round rubbing the dried excess. For the future the best way to apply grout to tile is to make the grout slightly more sloppy and apply it with a sponge, you can then sponge off the excess as you apply it.
Back to top
 Alert Moderators
Guest
PostPosted: Mon Apr 29, 2002 11:28 am Reply with quote
I would try a wire wool instaed of wire wall personally!!!
By the way, it is a long job, but it does work
Back to top
 Alert Moderators
jennysims
from United Kingdom
PostPosted: Wed May 01, 2002 10:49 am Reply with quote
Hi, I have a similar problem to the above. I am making a mosaic top dining table and the tiles are very rough to the touch with little pits in them. If I clean too much with a squeegee I end up lifting the grout from the gaps yet I cannot get all the grout from the surface of the tiles. Is there a special type of grout recommended for this sort of job? So far I've only grouted a small area but I really don't feel like continuing right now, this is turning out to be a very expensive project and I need to get it right.
Back to top
 Alert Moderators
Guest
PostPosted: Wed May 01, 2002 12:48 pm Reply with quote
I have removed excess grout on embossed tiles with a stiff brush. It is effective - but does take time.
Back to top
 Alert Moderators
Guest
PostPosted: Sun May 12, 2002 4:47 am Reply with quote
Try this new product manufactured by Tile Lab called Sulfumic Acid Cleaner available at Home Depot. This stuff works fantastic!!!!!
Back to top
 Alert Moderators
Guest
PostPosted: Thu Jul 18, 2002 1:15 pm Reply with quote
I am having the same problem. I bought a very textured, unglazed tile and applied the grout without first treating the tile with a sealer or grout release formula. Big mistake. I am in day 7 of hiring a guy to scrub for 4 hours. We use a wire brush and 5-in-one tool works good for taking off the high spots. The sulfumic acid does a great job of loosening the dried grout. Didn't learn about it until day 5, but it has made the job easier.
Back to top
 Alert Moderators
Guest
PostPosted: Tue Oct 01, 2002 4:24 am Reply with quote
does using the acid and steel wool take away the sealed coating thats comes on new sealed tile from the store.should it be sealed after your done.In some cases where the cement under the tile is a little high in your grout joints and there is very little grout covering those spots ,i find that acid takes away the grout in these spots,i have a very light grout and the dark cement underneath is now showing through.Is there any way of touching up those spots.Any help would be much appreciated.
Back to top
 Alert Moderators
Guest
PostPosted: Sat Jan 04, 2003 6:51 pm Reply with quote
IT IS VERY OLD WALL GROUT FROM BATHROOM
Back to top
 Alert Moderators
Andyaboutthehouse
from United Kingdom
PostPosted: Tue Apr 05, 2005 2:13 pm Reply with quote
Did the same thing myself about 18 months ago, Sulphumic Acid is definately the way ahead. Its quite nasty stuff though so wear gloves, goggles and vent the room. Says to keep it well away from skirting boards but in my case I had no option because they were covered too. Probably would have been easier to replace the boards in hindsight. It all worked out in the end - dont worry. icon_rolleyes.gif
MOD
then check the date this thread is over two years old
Back to top
 Alert Moderators
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Help removing excess silicone 7 1840 Sun Oct 19, 2003 6:04 pm
Grout Stain on Slate floor tiles. 2 1600 Mon Jul 26, 2004 2:43 pm
floor tiles, grout cracking 4 500 Fri Mar 12, 2010 12:05 pm
how to clean grout in bathroom tiles, 3 2120 Mon Jan 05, 2004 10:52 am
How do i clean grout off my glass blocks and tiles 4 1900 Fri Dec 10, 2004 2:53 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
