Hi
Hope you can help. The last couple of times I boosted my heating for 1 hour - it stayed on for hours! (although the programmer had switched off after an hour as normal). Can this be down to the mid postition valve? On the side of it, it has a switch marked W M H, and was still on H. I tried gently to move it but it didn't budge. There is also a switch at the bottom of it.
The make of the mid postition valve is ACL Lifestyle. Please can you advise it you think it is this that is sticking on, and if I should force it to M? Also, what does the switch do at the bottom?
