greenforehead
Joined: 11 May 2007 Posts: 10 Location: Kent, United Kingdom
Posted: Thu May 29, 2008 3:31 pm |
I know absolutely nothing about showers and yesterday my Triton Opal started leaking. It's about 6 or 7 years old and has been working fine. Yesterday I was using as normal and then hit the cold water button, turned the dial to 0 and changed the setting on the shower head for more power to rinse the bath. Then the water stopped coming out of the shower head and started spilling out of the short clear plastic pipe that comes out of the bottom of the unit just behind where the shower flex attaches (not sure if this pipe was supposed to have been plumbed in as an overflow? but in any event it wasn't and just extends about an inch down from the shower.) Obviously water spills out of this pipe now every time I try to use the shower.
I've had the cover off and everything looks ok but then I haven't a clue what i'm looking for.
Any ideas? Sound like me being stupid and an easy fix or time to call out an expert/replace the shower?
I do have pics with the cover both on and off but am having trouble uploading.
Thanks |
crockett
Joined: 15 Mar 2008 Posts: 915 Location: Berkshire, United Kingdom Thanked: 32 times
Posted: Thu May 29, 2008 5:52 pm |
sheslookinhot
Joined: 25 Feb 2008 Posts: 58 Location: Glasgow, United Kingdom
Posted: Thu May 29, 2008 6:21 pm |
Yes, the Pressur Relief Device, has gone. It will need replaced, fairly straightforward. It might have happened when you adjusted the controls, or maybe something else caused it. |
greenforehead
Posted: Thu May 29, 2008 6:53 pm |
cheers guys, looks like you've nailed it there thanks. Will get me a new one |
seco services
Joined: 03 Dec 2007 Posts: 15462 Location: Essex, United Kingdom Thanked: 1215 times
Posted: Thu May 29, 2008 8:24 pm |
blockage in showerheads, twisted hoses cause prd's to fail. |
parcol
Joined: 24 Aug 2008 Posts: 1 Location: Cambridgeshire, United Kingdom
Posted: Sun Aug 24, 2008 5:15 pm |
Hi
I have the same problem, it appears the pressure Relief Device has gone, same leaking from the plastic pipe, can you tell me if this fixed your problem and if so exactly which part do i need to order and is it easy to replace
Many thanks for all your help |
