Hi All,
I'm just about to embark on putting up some plasterboard in my kitchen. I've decided the best way forward for my level of diy skill is to put up some furring strips so i can get them nice and level and then fix the plasterboard to thoses with screws, rather than dot and dab and trying to play around with the plasterboard to get that level.
Now to the question. What is the best way to fill the joints etc. I've seen some self adhesive scrim tape which seems easy enough to use, but do i need to put joint filler in first before i apply the tape. Also i've seen jointing compound which i believe is to go over the tape. Is this necessary if i'm having the walls skimmed afterwards with board finish. I'm also assuming i will need to fill over the screws before skimming - is this correct.
Any advice, help or ideas would be appreciated.
Thanks for your help
