DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Help with Ohms reading on Multimeter XIOLE XL830L
Author Message
ukfrog
from United Kingdom
PostPosted: Fri Jun 20, 2008 3:38 pm Reply with quote
Hi all,
I have just got a Multimeter from ebay. I use to have an old needle one, but it was broken and had to replace it. So I did with the XIOLE XL830L.
I need help because Iíve only used this for Voltage testing, I a complete newbie.
What I need to do is test the resistance on the coils of my car.
Now when I use my multimeter, I get 1.3 on each coil (six pots). I conclude that Iím setting the multimeter to the wrong range.
Can some one help me understand this, in simple enfant language please. (what do I need to set my meter on if I what to be able to get this range)
Now I have the chart OEM chart for the readings.
OEM table ref.
Ignition coil resistance table for 6 cylinder.
Coil primairy 1(-) and 15(+) 0.4 Ė 0.8 ohms
Coil secondary N.A N.A
Can someone please help!
This is a link to a page where you can see what multimeter I'm using.
http://www.pchub.com/uph/laptop/524-31614-7625/UPH-XIOLE-XL830L-Repair-Tools.html
Cheers.[/url]
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 423 times
PostPosted: Fri Jun 20, 2008 4:04 pm Reply with quote
Plug the black lead to Com
Plug the red lead to the right hand terminal V/ohm/mA
Turn the selector to 6 o'clock (200 ohm range)
Touch the probes together - should read 0 ohms
Measure the coil resistance directly across the coils with the incoming wires disconnected.
Back to top
 Alert Moderators
ukfrog
from United Kingdom
PostPosted: Fri Jun 20, 2008 4:57 pm Reply with quote
Cheers, I thought I was doing it wrong.
It stops at 2M but manual says 2M-1K. Is 1K more than 2M? is it over 20M?
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 423 times
PostPosted: Fri Jun 20, 2008 5:00 pm Reply with quote
If you are wanting to read up to 200 ohms (lowest range) then you need to be on the 200 ohms range.
M = Mega or million ohms
K = Kilo or thousand ohms
If you are reading M ohms across the coil then it is open circuit and useless.
Does the meter go to zero when you are on the 200 ohms range and you touch the probes together?
Back to top
 Alert Moderators
ukfrog
from United Kingdom
PostPosted: Fri Jun 20, 2008 5:06 pm Reply with quote
Touch the probes together - should read 0 ohms.
When I do this, it reads 00.8. Does that mean it's a bit off?
Because I should get 0.4 to 0.8 on the coil, but I get 1.3. is it the 00.8 difference that makes my reading faulty?
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 423 times
PostPosted: Fri Jun 20, 2008 5:07 pm Reply with quote
yeah, if you subtract the 0.8 ohms (possibly lead resistance) from your reading then it is within spec icon_biggrin.gif
Back to top
 Alert Moderators
ukfrog
from United Kingdom
PostPosted: Fri Jun 20, 2008 5:11 pm Reply with quote
icon_mrgreen.gif icon_razz.gif icon_mrgreen.gif icon_razz.gif icon_mrgreen.gif icon_razz.gif icon_biggrin.gif icon_mrgreen.gif
Thanks champ!
You've been of great help.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
ohms resistance 11 821 Wed Mar 24, 2010 9:15 pm
ze 12 ohms 44 860 Mon Aug 08, 2011 6:14 pm
Ohms law in theory and practice 21 400 Sun Sep 11, 2011 1:28 pm
200 Ohms 14 940 Sat Apr 01, 2006 8:14 pm
One leg of ring main low ohms between all conductors 15 940 Wed Dec 02, 2009 10:19 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
