Joined: 03 May 2002 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Fri May 03, 2002 3:44 am Post Subject:
Lead flashing
I was hoping to find info re max runs of lead flashing and max overall size of lead flashing recommended. My problem is leaking lead work on new conservatory. Builder has used short strips contrary to spec on drawing and claims larger strips are not suitable because of need for expansion. He proposes to seal joints with silicone seal which I fear is a 'bodge'. He has also (separate job) repaired flashing on a chimney, he has tucked the lead into a slot cut in the chimney but has used silicone seal. Again I suspect a bodge, but he says its OK. I seek advice if you can offer it. Any chance of speaking by phone?
Can I fax you with diagram of large area of flashing on conservatory roof, specified as opne sheet to deal with a triangular shape which gets narrower as you go down the roof?
Would greatly appreciate some help, have not paid builder but I think he is about to get nasty and considers he knows best way to solve leak whereas I think he should have done the work to spec on architect's drawing.
If you don't want to see this advert, click here to login or if you are new click here to join free.
Guest
Posted: Wed Jun 05, 2002 2:02 pm Post Subject:
Re: Lead flashing
lead flashing should be split into short lengths, typically max of 1.5m long for code 4 flashing. there is a special lead sealant available for jointing. wickes do an informative leaflet on 'using lead sheet' (no 22)
I recently flashed my conservatory roof myself. I cut about 1 inch into the stone wall of the house using a diamond saw, then inserted 1.2m long strips of lead (230mm wide code 4 roll from Travis Perkins) horizontally with a 20cm overlap between sections. The lead was secured to the wall using lead wedges hammered into the slot above the sheet every 12" or so. I used no silicone. I have had no leaks so far!
I agree - try to get Wickes leaflet 22 - it contains all the info you require.
Also "Calder" produce a free leaflet on what's required - a builders / roofing merchant should have a few copies
if he has used lead mate,that is not a bodge,it is used in a silicon gun as an alternative to pointing with muck
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
