Hi All,
Have a boiler, 1993 non- combi - Prima F
New hot water tank
British Gas cover 400 (they have tried to insist I get a power flush, oh yes, that old commission based chestnut)
Problems: Hot water in rads when only hot water for tank is required (motorised valve faulty?)
Overflow chucks water out from attic for many hours a day whether the heating is on or off (though does seem to influence this at times)
All related issues?
Have had a new HW tank fitted and raised the breather pipes in attic as they were too low, but I think the overflow happens via the breather pipe as well as coming back up through the system from below ... confusing I know ...
British Gas keep banging on about the power flush and have been quite aggressive, I think I will get them to fix this and then jack them in.
So ... wht do you all think the issue is?
Cheers
Jimbo
New hot water tank
All related issues?
Cheers
Jimbo
