- Joined
- 25 Jul 2005
- Messages
- 36
- Reaction score
- 0
- Country
I'm about to build a post and rail fence as a boundary around a raised concrete / tiled terrace. The fence will be 1 metre high with 40/50cm bolted to the side of concrete block terrace.
The longest run will be 13 metres. Based on the size of the rails available to me here (3m long, 12cm wide) I plan to have posts every 1.5m which I imagine will make for a sturdy fence. Doing this makes best use of the 3m rail lengths and although increasing the number of posts (I'd originally worked on 2m spacing between the posts) reduces the total cost due to less wastage on the rails.
So - based on 1.5m between posts, what diameter do you think the posts should be? Is 6cm by 6cm enough, of should I do for 10cm by 10cm for example?
Thanks for your help.
Richard
Richard
