wadge
Joined: 20 Dec 2006 Posts: 41 Location: United Kingdom Thanked: 2 times
Posted: Fri Aug 01, 2008 11:25 pm Post Subject: Using Celotex |
Bit confused here. I've got a single skin block wall which I want to insulate with Celotex.
So the plan is as recommended by their website:
Wall - Celotex (with joints sealed by foil tape) - 25mm battens screwed through Celotex into wall - plasterboard screwed to battens.
The website talks about using a membrane...where does this go and which way should it face? Can I use the same breather membrane like I used under the roof tiles?
Should I use a polythene sheet inbetween the block and Celotex to stop water coming through? |
mikric
Joined: 06 May 2007 Posts: 406 Location: Lincolnshire, United Kingdom Thanked: 3 times
Posted: Sat Aug 02, 2008 1:03 pm Post Subject: |
Normal application is to put the membrane against the outside wall then the celotex, but in theory its up to you, the foil backing on the insulation acts as a vapour barrier in itself. |
wadge
Posted: Sat Aug 02, 2008 1:45 pm Post Subject: |
Thanks. The barrier membrane has printing on it saying 'face this side out'. So does that face the inside of the room or the brick? |
mikric
