Any good electrical wholesaler will stock or be able to order Hager accessories. Try TLC, Edmondsons Electrical, Newey & Eyre, CEF or search on google or yell.com for wholesalers in your area.
You should not mix different brands in a consumer unit as they will not have been tested or certified for use with each other and will most probably not fit correctly either.
