DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Join garage to house
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
P.J.
from United Kingdom
PostPosted: Tue Oct 05, 2004 4:18 pm Reply with quote
Thought I'd run this one by you for some thoughts:
I have a detached garage that sits at about 30 degrees to the house. The front of the garage is about 1m away from the front corner of the house.
I'm looking to cover the triangular area between the garage and the house and add door access from the house into this area. The official line is that it's to add a utility room outside the kitchen, although I'll be getting a bigger garage at the same time icon_wink.gif
I'm considering a single skin brick wall (same as garage construction) joining the garage to the house front and rear, with a flat roof on top. The bottom of the existing house-side garage wall could be removed and the garage roof supported with the necessary steel work. The garage door would become about 2 or 3 foot wider and the floor space would become like a triangle with the main point cut off.
Does that sound feasible ? Any other options recommended?
I understand its difficult to visual from the explanation but all constructive comments are appreciated. icon_biggrin.gif
Cheers,
P.J.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Wed Oct 06, 2004 10:10 am Reply with quote
Sounds okay but what I will say you need to follow the building regulation, pop down to your building control with a rough drawing & they will advise what need to be done. They will be very helpful. You might need a footing with a double wall etc. If you sell your property without following the building reg, you may find you have to convert it back, I know this goes on all the time but thought I should pointed it out first.
Back to top
 Alert Moderators
P.J.
from United Kingdom
PostPosted: Wed Oct 06, 2004 3:55 pm Reply with quote
Cheers, masona, appreciate the advice.
Regards,
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Expansion join in garage base? ~6m by ~5m. 2 60 Mon Aug 04, 2014 7:19 am
RSJ PFC join 3 60 Tue Sep 13, 2011 6:13 pm
Fine dust falling from ceiling/wall join 8 620 Wed Oct 06, 2004 1:04 pm
Fireline Plasterboard join/seal 2 560 Tue Mar 23, 2010 9:29 am
crack appeared on join with new stud wall 2 80 Thu Mar 27, 2014 8:36 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
