No Heating, Synchron Motor not turning
6 Oct 2004
Does anyone have any ideas in regards to my problem. My central heating won't come on, when I have the CH turned on and turn the thermostat up to turn the CH on nothing happens. If I turn the Synchron motor manually using the lever opens the values and presto hot radiotors. Do I just need to replace this motor?
First of all you need to check if there is power on the synchron when the thermostat is calling for heat. If there is then you're right - it's the motor.
